Bigger Wheels and Tires?
Old Dec 11, 2011 | 12:19 AM
co09packers's Avatar
I have a 100% stock 2007 F150 and want to put bigger rims and tires on her, but idk how to go about doing so. Any suggestions??
Old Dec 11, 2011 | 11:05 AM
Big_Smokey's Avatar
Whats the budget ? is it a 2wd or a 4wd ? How big are you wanting to go?
There are a bunch of posts to look over first. so if you can use the search engine. I think there is a sticky in the suspension section that is kind of a guide line to what size tires with what size lift will work on your truck
A cheaper way is to do a leveling kit and run a 33-35" tire..Do some research first though and find out whats best for your wants and needs.... RIM backspacing/offsets are also important when picking out what size tire with which lift you decide.
Old Dec 11, 2011 | 11:34 AM
atr04screw's Avatar
How much bigger are you wanting to go? You can fit a slightly larger and wider tire just stock, or you can go with a leveling kit and get a 33s or 35s (depending on if the truck is 2wd or 4wd), or you can do a 4" or 6" suspension lift.
Old Dec 11, 2011 | 12:35 PM
Galaxy's Avatar
What look do you want?? Aggressive mud or mundane all terrain? Do you need a practical tire or would you rather have something you enjoy lookin at every day? Just a couple more decisions to make.
Old Dec 11, 2011 | 01:04 PM
54regcab's Avatar
265/70/17's will fit stock 4x2's (come as stock on some 4x4's). Any bigger than that and the price jumps quite a bit. I guess 265/70/17 is the largest common size...
