Best 2WD Rotor/Hub Brand for 07
Old Nov 7, 2011 | 06:16 AM
kjf-150's Avatar
Okay so with 130,000 miles on my moms 07 F-150 2WD the front rotor/bearing/hub assembly is shot...again. I replaced them once around 70,000 miles, and 60,000 later the bearings are shot again. Its making the same scrubbing noise, as well as vibrating pretty bad. Last time I used the cheaper ($80 maybe) rotor assembly from carquest. This time around I figured I would use a little better rotor that would last a little bit longer. What would you recommend/have had better luck with? I'm used to Super Duty's so I'm a little lost when it comes to F-150's. Any suggestions would be greatly appreciated!
~Kevin
Old Nov 7, 2011 | 08:56 PM
54regcab's Avatar
From what I've read people have been modding these wit ha new system that keeps the rotor and bearing separate. The new system uses the 4x4 rotors. Not sure on the details and didn't see a writeup on it.
