Different tire size do any harm?
Old Sep 15, 2011 | 03:02 PM
mkinttrim's Avatar
I'm currently running BFG A/T 285/70/17's on my 05 F150. It has a 3:73 LS rear end. My spare is the stock that came with the truck, I think its 265/75/17. If I ever get a flat will running the different size screw anything up? I plan on getting new set of tires next spring so may transfer best old one to spare if it would help. So far 55K on these tires and still have 7/32 left.
Old Sep 15, 2011 | 03:12 PM
kingfish51's Avatar
I doubt very much that your spare size is 265/75R17. More likely it is 265/70R17. If you get a flat, make sure the spare goes on the front and that you do not use 4wd. Otherwise you could tear things up.
Old Sep 15, 2011 | 03:29 PM
mkinttrim's Avatar
Yeah you may be right, just didn't want to crawl underneath the truck.
Old Sep 15, 2011 | 04:18 PM
atr04screw's Avatar
Since you have the limited slip, the rear tires have to be the same size. If they are different sizes and you get a flat in the front then you can just swap it for the spare. If you get a flat in the back, then you will need to swap a good tire from the front to the flat in the back and put the spare up front.
