Looking to do a 6+3 and 37s on my '03 Screw. Do I go with 10" or 8.5" wide rims
Hi all
In the next 3 weeks i'm looking to install a 6+3 on my 2003 Screw Fx4. I'd like to run 37s (maybe Toyos...but still looking around).
The rims I want are the rockstars. I've seen them in 20x8.5 and 20x10 (for the 5x135 bolt pattern).
What I don't know is which width to go with. With the 10" pose problems rubbing? Or perhaps the 8.5" isn't wide enough for a 13.5" tire?
Any help would be appreciated.
I believe the Rockstar specs are as follows:
20x8.5"
+10mm offset
5.14" BS
20x10"
-24mm offset
not sure on BS
Lastly I'm still searching for tires. Looking for the aggressive yet streetable (on a daily driver truck). So far Toyos look awesome. Any other suggestions would be great.
Thanks!
20x8.5"
+10mm offset
5.14" BS
20x10"
-24mm offset
not sure on BS
Thanks!
I have a 03 and have nitto mud grapplers on my truck. They will not last nearly as long as a set of toyos but they look mean, sound great and do amazing in every road condition. I have taken it in sand, mud, clay, snow and whatever else and never had one issue. I know your concerns may not be the same but if you want to turn heads then they definitely do the trick. They are expected to last 30-40 thousand. I would imagine mine are on that route as well.
