Anyone have STOPTECH Brake Lines Installed?
Old Jul 10, 2011 | 12:12 PM
index1489's Avatar
Well I just finished installing a new hub/wheelbearing assembly, stoptech rotors, pads, calipers.
I got to the brake lines but didn't install them because they look a little different then the stock ones.
Anyone have these installed?
06 F150 2WD
Also is the stock caliper made of aluminum?
Old Jul 10, 2011 | 05:50 PM
index1489's Avatar
just tried to install the brake lines, ran into a problem, the end of the stop tech line is round, the OEM one is round with a flat area, so the stop tech line won't fit in the bracket, and I was unable to use it, as pictured.
Old Jul 10, 2011 | 06:01 PM
index1489's Avatar
I just tried to install the brake lines, ran into a problem, the end of the stop tech line is round, the OEM one is round with a flat area, so the stop tech line won't fit in the bracket, and I was unable to use it, as pictured.
Centric Parts forwarded your request and asked us to help.
The StopTech 950.65004 stainless lines are only used on the new body style Ford F150 2WD & 4WD models from 2004 - 11/2005. They do NOT fit the Heritage (old body style) and they do not fit the new body style models made after November 2005.
What is the configuration and date of manufacture of your Ford F150? Once I know your specific model, I can help you find the correct lines.
Sincerely,
David Zeckhausen
President, Zeckhausen Racing
(800)222-8893 x1
www.zeckhausen.com
Mabye I need 04-05 brackets?
I have the lines installed everything works except the brackets, used a bunch of zip ties.
