which size tire & wheels on OEM
Old Jun 22, 2011 | 04:14 PM
honestlarry's Avatar
Just found a 2011 SC lariet loaded, my ? this truck has the factory 20"
the dealer claimed he would switch to 18" if did not like the 20s
any likes or dislikes or just what is the diffence plus or minus
thanks
Old Jun 22, 2011 | 04:42 PM
jerrybizzle's Avatar
20s will have a little stiffer sidewall as there is less of it and replacement tires will probably be a bit pricier. If I were you I would get the truck with the 20s if its the same price and if you don't want them, sell them and get custom rims.
Old Jun 22, 2011 | 05:00 PM
20" wheels
Another thought the window sticker price on the 20s is $595.00
which the dealer claimed would be adjusted. also said anything to make the sale. we have all heard this. if that is taken off i am leaning for the 18s
the 20s are pirellas (bad spelling) which after searching most do not care for this tire. working on this purchase tomorrow thanks
Old Jun 22, 2011 | 05:48 PM
If they adjust the price then by all means go with the 18s. If not you are short changing yourself.
Old Jun 22, 2011 | 05:49 PM
mdhawkin's Avatar
I would do two things. One find out what 18's he is going to give you make sure they are standard to the trim package and that you like them. That way they do not make money by giving you a wheel cheaper than what is standard for that trim package. Second since it is a upgrade its the 595 is the price difference between the 18's and the 20's. So the full amount should be discounted in the adjustment. Good luck.
Old Jun 22, 2011 | 05:59 PM
20 inch
If i go with the 18s, which i most likely they would have to the off a lariat
and the total window sticker price. the SC LARIAT WHITE TWO TONE loaded is harder to locate this late in the year
