keeping wide tires balanced?
how hard is it for the people running tires 12.50 inches wide and wider to keep the tires balanced? are yall maintaining a stock feel ride after a wide tire install ?
im running a 18x9 4.5 inch bs with a 33x13 tire, and ive had to get them balanced after 1000 miles cause of vibration bad. its a new set up probley only got 1500 miles on the tires total now, do i just need to get them balanced a few times for it balance to settle in so i can get about 5000 miles in or something or is it just the case with haveing this wide of a tire, there keep clean so i know mud isent kicking the balancing out? thanks for the reply
since you have aftermarket wheels, make sure they are balancing them correctly, and all the way out to 0.0..ive seen places "balance" out a 35,37" tires and get them down to .5 ounces and give that "ehh" shoulder shrug and say "good enough" or "close enough" and stick the tire on the car
