torque spec
Old Apr 17, 2011 | 09:24 AM
dnjsyl's Avatar
torque spec
can anyone tell me what the torque specs are for the lug nuts on a 1998 f150........one of the studa broke off on me and i just want to make sure i dont oveertighten them again...thanks
Old Apr 17, 2011 | 09:41 AM
Ford12508's Avatar
You overtightened them that much? Either lay off the juice or put the impact gun down.
My 1999 expedition is 100 ft-lbs, probably the same with your F150. I am at work, but I have a chart at home that has every car from the 70's until now and its lug nut torque. If no one answers otherwise, I will get back to you tonight.
Old Apr 17, 2011 | 09:55 AM
kingfish51's Avatar
The torques spec for the 98 is 100 ftlbs. It is even stamped onto the lug nuts if you look carefully.
Old Apr 17, 2011 | 10:26 AM
hardrock3742's Avatar
should be 90 or 100. I used to work at discount tire
Old Apr 17, 2011 | 06:02 PM
dnjsyl's Avatar
i guess ill have to lay off the juice...ha ha....i was using a lug wrench....thanks guys i appreciate the advise
Old Apr 17, 2011 | 07:35 PM
Daniel09's Avatar
yup 100lbs
