replacing rotors 93 150 2w drive
Old Jul 3, 2001 | 04:50 PM
louisdee3's Avatar
Question replacing rotors 93 150 2w drive
Hello ,my question is I need to put new rotors on my 1993 2 wheel
drive F150,and i want to do it myself,i would like to know is it difficult to do .Does it involve messing with the wheel bearings,should i replace the bearings? I always do my own brakes,but this is a first for me . Thank you
Old Jul 4, 2001 | 12:11 AM
buckdropper's Avatar
From: south western NYS Latitude: 42.34 N, Longitude: 78.46 W
Talking piece of cake
it should be no problem and i would replace the bearings unless they have been done recently. The back one is held in with a race also replace this.
Old Jul 8, 2001 | 02:27 AM
fordtec2001's Avatar
when replacing the rotors clean the wheel bearings for damage or cage being crack if not then repack the bearings and replace the grease seals and alway use a new cotter pin
push back the piston in the caliper with a c clamp check for rips in the dust cover on the calipers too
lube the caliper pins and rails ( where the pads sit on the anchor ) its easy job do one side at a time so you can go back and check for any mistakes
good luck
