3" body lift
Best way to tell is measure the clearance between ground and the top center of the fenderwell at both front and back. My back sat higher than my front by about 2.25" so I went with the 2.5" and now my front is a little higher.
Nobody on here really recommends doing more than a 2.5" level because of the stress it puts on the ball joints and such by changing the angle. I would do the 2.5" level and see how you like it or you could look at Bilstein shocks.
I have a 3" HBS level kit on the front of my truck for a couple years now with no extra wear & tear so you will be fine with a 3" level I also have a 3" PA Body Lift which I think looks good with the level. I got a total of 6" of lift over stock between the 2 lifts. You can see for yourself if you like it or not. Oh but mine is not a 2wd its an FX4. Just make sure you get the Gap Guards for the Body Lift.
