No brake lights? Checked all fuses......
So im leavin dunkin donuts earlier, and a woman pulls next to me and tells me i have no brake lights at all, not even the third one, so i pulled right back in the lot and checked all the fuses...all are good...Any ideas??
By saying you have no brake lights, i assume you have tail lights but nothing changes when you hit your brakes? Or do you have no illumination coming from the tail lights at all? I believe your truck has a brake light switch, let me do a quick search. . .
The search button can answer almost any question you may have. . .hope this helps
https://www.f150online.com/forums/el...-thoughts.html
The only reason im thinkin its not the pedal switch is because when pedal is pushed you can still shift in an out of all gears...if that switch is bad, doesnt it lock the shifter??
Now that's a question I can not answer. Based on a quick google search the part you need is less than $20. I would rather waste $20 on a part that did not work than risk the chance of a $$$ ticket or being rear ended. Someone here will probably chime in soon and clarify the issue for you.
