Recomendation?
Old Jan 24, 2011 | 02:09 PM
Ford#1
Guest
Posts: n/a
Recomendation?
I have a F150 Platinum and I would like to put some wheels and tires on, I really do not want to lift it, I. So, I guess my question is, will it be possible to do this without lifting it? Would it look bad? I am pretty much new to all these mods, but looking for ideas on what to do. I have seen some post about leveling, I guess this is what I would have to do for tires if I do not put on a lift? Thanks
Old Jan 24, 2011 | 03:24 PM
ab46501's Avatar
You can put new wheels and tires on without a level or lift. The only thing a level or lift does is give you more clearance for larger size wheel/tire combinations. I would probably do at least some leveling just cause it looks better IMO but it's not something that you would have to do.
What size wheels and tires are you thinking about?
Old Jan 24, 2011 | 07:17 PM
f150fella08's Avatar
id get a leveling kit, that away you could run a 33" tire and it would look real nice
Old Jan 24, 2011 | 08:24 PM
Ford#1
Guest
Posts: n/a
I am really not sure what size tires to tell you the truth? Not overly big, I have always liked BF Goodrich T/A's probably 30"-32"?
Old Jan 24, 2011 | 08:57 PM
ab46501's Avatar
Your stock tires are 32 inch. I wouldn't go any smaller.
Old Jan 24, 2011 | 09:36 PM
wandell's Avatar
Do you have a 4x4 or 4x2?
Old Jan 25, 2011 | 12:22 PM
Ford#1
Guest
Posts: n/a
Originally Posted by wandell
do you have a 4x4 or 4x2?
4x4, I guess I should put some info in my signature.
Old Jan 25, 2011 | 12:41 PM
wandell's Avatar
Yeah, that would help. I'd suggest going with a 9 inch wide wheel with 5 inches of backspacing and a 33 inch tire. Personally, I'd go with 18's.
Old Jan 25, 2011 | 08:41 PM
moonwolf's Avatar
you could go with a 34" tire without any mods, as long as you keep the same specs as your stock rims.
