Can i use these size tires.
Old Jan 3, 2011 | 08:04 PM
Legend_2005's Avatar
Hey guys. I have an 06 F-150 lariat 2WD with the factory 20 inch wheels. I have factory 275/55/20 on it now and i would like to go to a 285/65/20 BFG All Terrian. Will they work or could i go bigger? The truck does have a 2.5 leveling kit on it. If yall could give me some feedback on this that would be great. Thanks.
Old Jan 3, 2011 | 09:40 PM
wandell's Avatar
I think that would be pushing it too far. I'd go with a 285/55-20 (33x11.50) or a 305/55-20 (33x12.50).
Old Jan 4, 2011 | 03:51 PM
Under Dog's Avatar
On my 4x4, I run 275/65/20 BFG A/T's, without a level kit. Equals just about a 34" tire. No rubbing, but I could not go bigger. But again, mine is a 4x4. I think the 2wd's sit a little lower then the 4wd's.
Old Jan 4, 2011 | 04:42 PM
Well i have a 2.5" leveling kit on the truck and it sits up just as high as a 4x4. I really want to go with a taller tire for the extra clearence. I know a 65 is not much taller, but where i live every little bit will help.
Old Jan 4, 2011 | 05:03 PM
NCSU_05_FX4's Avatar
I fit 285/65/20 on my FX4 with a 2" leveling kit, no rubbing, but I was running aftermarket wheels with very similar offsets/backspacing. They should fit with OEM wheels, but it'll be tight.
- NCSU
Old Jan 4, 2011 | 05:16 PM
tg150's Avatar
I've got 285/65/20 BFG AT's on OEM 20's with a 2.5" leveling kit. It is a 4x4 though. I have no rubbing at all.
Old Jan 4, 2011 | 09:56 PM
wandell's Avatar
4x4's sit 2 inches taller than 4x2's.
Old Jan 4, 2011 | 10:18 PM
Yeah thats what i hated about mine when i got it. I couldnt stand it sitting as low as it did in the front. The first upgrade to the truck was a 2.5" leveling kit. As i said before it is a 4x2. With the leveling kit i think i will be able to run the BFG AT 285/65/20.
Old Jan 5, 2011 | 12:52 PM
wandell's Avatar
They may fit, but they will be really stuffed. Let us know if they fit ok.
Old Jan 5, 2011 | 01:42 PM
Went to NTB earlier to see about the tires. The guys at the location didnt really seem to know what they were talking about. They said that a BFG 285/65/20 was not even available. I know they are cause some of yall on here have them. Also he said they would 100% not fit. After about ten min of the guy running around looking at books i just left. Went down to a guy i know at Discount Tire and told him what i was looking for. Just so happened that a guy was there getting some Nitto Terra grapplers(sp?). They were 305/55/20 on OEM wheels. They fit, but just barely! So with knowing that i am pretty sure that the BFG 285/65/20 will fit. I got them on order and will let yall kow how they fit.
Old Jan 5, 2011 | 03:51 PM
Under Dog's Avatar
Good deal, I wanted to run the 285/65's, but couldn't at the time, justify the extra money it would of been for 10mm more width. So I got 275/65, and couldn't be happier.
Old Jan 6, 2011 | 07:01 AM
Well got the tires on yesterday and the truck looks great!! I did end up going with 285/65/20's. I have very very little scrub. It just taps the iner finder in a shap turn to the right. I am going to modify it alittle and ride. Thanks guys for all you input.
Old Jan 6, 2011 | 08:23 AM
Awesome! Post some pics when you get the chance!
- NCSU
Old Jan 6, 2011 | 01:32 PM
well.... if i knew how to post pics i would. not much of the computer person.
Old Jan 6, 2011 | 02:43 PM
Derrick@TireRack's Avatar
Former Sponsor
I think the 285/65R20 will be to big. Would look for a size closer to 33" tall.
