305/55r20 or 285/55r20?
Old Dec 16, 2010 | 11:42 PM
tkay84's Avatar
I recently purchased a 2004 f150 screw 4x4 with a 2" AS leveling kit on it and ordered 20x9 Incubus Poltergiest 501 wheels with +30mm offset. Will 305/55r20 terra grapplers fit with out rubbing or do I need to go with 285/55r20?
Old Dec 16, 2010 | 11:44 PM
the_cosworth's Avatar
Why would you go with 285/55? 305 55 is at least a 33" tire.
I dont see why a 305/55 shouldnt work. However you could have SOME rubbing because of the height. You wont have a problem with the 305 portion though.
Old Dec 17, 2010 | 12:00 AM
sparkyb34's Avatar
i would think it would work, you could also look at 275/60. they are 33" tall and 11.5 wide, plus cheaper
Old Dec 17, 2010 | 12:03 AM
tkay84's Avatar
The 285/55 are under 33" and the other option I was also looking at was the 295/60 but it is a 34.45" tire and that is a little to big, so I narrowed it dowm to the 285/55 32.28" or 305/55 33.07". I'd like to go with the 305/55 cause I think it would look better but I don't want to spend the extra money and deal with rubbing issues.
Old Dec 17, 2010 | 12:07 AM
tkay84's Avatar
I did consider the 275/60 but ruled them out because I am looking for a tire with over 3000lb max load because I do haul round bales every summer.
Old Dec 17, 2010 | 07:30 AM
Big_Smokey's Avatar
Here is your choices that you will be happy with.....305/55/20..which is what im running with a 4.5" of backspacing or if you are going to go a little skinnier of a tire. 285/65/20.... With your positive offset you can tuck a bigger tire....just remember just because the first number is bigger, that doesnt mean the diameter is bigger.... That last tire i told you is like a 34/11/20....the 305 is.....33/12.60/20...Do alittle reasearch on here and you will find what you are looking for.
Just for a reference...im running a 35.1250.17 on my truck in the winter.........so there is plenty of room with these trucks
Old Dec 17, 2010 | 02:08 PM
wandell's Avatar
You are basically comparing a 33x11.50 (285/55-20) and a 33x12.50 (305/55-20). Both will fit/work/look fine.
Old Dec 17, 2010 | 03:18 PM
Derrick@TireRack's Avatar
Former Sponsor
That will work just fine with no modifications.
Old Dec 17, 2010 | 05:47 PM
tkay84's Avatar
Thanks for the help guys. Just ordered 305/55r20.
Old Dec 17, 2010 | 10:10 PM
tdsports's Avatar
Good choice with the 305/55/20. Just installed a set of nittos today and couldnt be happier. They were kind of close up front but havent had to trim at all and no rubbing at full lock.
Old Dec 18, 2010 | 12:35 PM
do you have any pictures?
Old Dec 18, 2010 | 04:41 PM
tdsports's Avatar
This is the only picture I have right now. Will get one showing how close here soon.
Old Dec 18, 2010 | 07:43 PM
Cheers, thanks, that is the next combo I want. 2" level on the front?
Old Dec 19, 2010 | 10:38 PM
tdsports's Avatar
The level was on there when I bought the truck so I'm not sure if it's 2" or 2.5".
