Snow Tires
Old Dec 6, 2010 | 08:17 PM
uthman's Avatar
Snow Tires
I'm in the market for snow/winter tires for my stock 18" wheels (they're currently off). I've found some that are a really good deal, but I'm not sure if they'll fit my SuperCrew FX4. They're 245/60-28. Should I be concerned about the profile height, width, etc...? Thanks
Old Dec 6, 2010 | 08:36 PM
Wiplash06's Avatar
Federal M/t looks great. Check them out online.
Old Dec 7, 2010 | 11:22 AM
Derrick@TireRack's Avatar
Former Sponsor
what year is your FX4?
Old Dec 7, 2010 | 12:11 PM
mkosu04's Avatar
I'm pretty sure that 245/60-28 tires will NOT fit on your 18" rims...
But perhaps you mean 245/60-R18 ?
The tire manufacturer should state what bead width rim the tire will fit on. I'd be worried that a 245 may be too skinny to seal well on the bead... but check the wheel and check the tire info and that will decide it for you.
Other than that, a skinnier tire is generally better in the snow so you should be OK.
The stock size on FX4 is 275-65-R18 by the way... So using this tire will change your speed so you will need to reprogram your speedo...
