Am I right?
Old Nov 28, 2010 | 05:17 AM
TripleJ79's Avatar
Am I right?
I ordered some 18x9 ballistic jesters(-12 offset) for my 06 screw...I plan on running 285/65 18 trail grapplers with them.I have a 2.5 as and a 1 1/2 aal.Will I rub at all? I want the tires to stick out a little...I searched the threads and saw a +12 offset that stuck out pretty far from stock but I guess what I'm asking is did I order the right offset or do I need to return the -12s and get the +12s?...How far will the -12s stick out???? Past the +12s??? I appreciate any help you can give me....
Old Nov 28, 2010 | 10:38 AM
wandell's Avatar
What backspacing does +12mm and -12mm offset work out to be?
Old Nov 28, 2010 | 03:35 PM
TripleJ79's Avatar
The -12 has a 4.5 bs and the +12 has a 5.5 bs.I do want them to stick out but I guess I just need to know how far each one will stick out pass stock.
Old Nov 28, 2010 | 09:52 PM
wandell's Avatar
A 9 inch wheel with 4.5 inches of BS will stick out 2.5 inches farther than the OEM wheels. 5.5 inches of BS will make it stick out 1.5 inches farther than your stock wheels.
Old Nov 28, 2010 | 10:32 PM
TripleJ79's Avatar
So with 285/65 18,I should be good?
Old Nov 28, 2010 | 10:33 PM
TripleJ79's Avatar
No rubbing is what I meant...
Old Nov 29, 2010 | 12:55 PM
wandell's Avatar
You will be fine.
