2001 F-150 4x4 4WABS ABS light on all the time
Old Nov 22, 2010 | 12:01 PM
spwjones's Avatar
Folks,
Recently my ABS light came on and frequently went back off. Changed the rear sensor with new. Noticed the abs light on constantly. Pulled codes C-1096 ABS Hydralic pump motor circuit open. I had the abs module tested by BBA Remanufacturing in Taughton, MA, and they stated it was ok.
As a side note the rear sensor wire seems to be on a pivot connection type of lead that rotates, perhaps to compensate for the rear end movement. Has anyone notice that? Has anyone found a problem with that lead??
In any event the abs light is on all the time from the beginning after engine starts, until I shut the engine off.
Any mechanics out there with suggestions.
I hear people talking about an ABS relay. Is there an ABS relay? I don't see it in the owners guide.
Thanks Much
SPW
2001 4x4 Supercrew cab 5.4L engine with 4WABS
Old Nov 22, 2010 | 12:40 PM
ncTidalWave's Avatar
Have you checked the ABS fuse?
Old Nov 23, 2010 | 09:13 PM
spwjones's Avatar
Fuses checked for ABS light on all the time
Fuse 15 ok ABS 5A
Fuse 23 ok 4WABS systems module 10A
Fuse 102 ok Four wheel anti-lock module 50A
Any others I missed??
