back again
back again
Alright guys I'm back again with more questions on this tire/wheel thing. Ive almost 100% decided to get a 20" wheel with 35's. Def. putting the body lift on too so i can fit the bigger tires (already have a t-bars cranked) On the wheels there are different sizes like 20X10, 20X9, and i think 20X8.5. IS this the width of the wheel im guessing? I dont want a set of tires that are wide and stick out from the wheel wells, so would i want the 20X9 or go with the 20X8.5? pics would be appreciated just need some help thanks!
The width of the wheel is not the only factor that goes into how far a wheel will stick out. You also have to take into account offset and backspace. If I were you I would use the search feature to find members' combos that you like and figure out what specs there wheels have.
I assume you have a 97-03 4x4 since you mentioned torsion bars. A 10 inch wide wheel with 4.5 inches of backspacing will put the edge of the tire/wheel just about even with the edge of the fenders. I have pics in my gallary.
