325/65/18 on factory rims w/2.5" level?
Old Nov 18, 2010 | 04:40 PM
HessFx4's Avatar
325/60/18 on factory rims w/2.5" level?
Was wondering if 325/60/18 would fit on my factory 2005 fx4 rims with a 2.5" leveling kit?? Tire is 33.35x12.8 you think it will fit with maybe a 1/4" spacer?
Old Nov 18, 2010 | 04:47 PM
mdhawkin's Avatar
They will fit, how much they rub will depend on the sidewall. However, eventhough they will go on, does not mean you should. That tire is a little wide for the 7.5" wide wheel.
BTW what tire are you talking about?
Old Nov 18, 2010 | 04:56 PM
HessFx4's Avatar
Ok well they are a set of toyo open country all terrain, that have 5k miles on them that I can get for $450 so I figured it would be worth it?? Or would it be bad fir the truck?
Old Nov 18, 2010 | 05:40 PM
brazzeal15's Avatar
Yes.. they will fit. Ive dont this size on an FX4 before but with Nitto and a 2" AS. They are essentially the same exact tire. Your good.
Old Nov 18, 2010 | 05:59 PM
HessFx4's Avatar
Did you have to use spacers?
Old Nov 18, 2010 | 11:23 PM
brazzeal15's Avatar
No the guy didnt want us to so we didnt. May need a little trimming of the inner fender wells, but nobody sees that anyways.
Old Dec 3, 2010 | 09:42 AM
HessFx4's Avatar
Hey guys I bout those tires, and the guys at the tire said they will rub like heck and won't fit even with a spacer.. It's a 325/65/18. It's a 12.8" wide tire..
Old Dec 3, 2010 | 07:39 PM
Now it's a 325x65x18, that's a 35x13 tire and will give you fit's to make it fit even though some have done it. It's all about how much you want to hack up your truck.
Old Dec 5, 2010 | 05:16 PM
chunky50's Avatar
won't fit
no they will not fit i have tried 325/60/18 and they rub on the upper a-arm sitting still on stock it cost me $200. to get them installed. you need wheels or spacers.
Old Dec 8, 2010 | 11:49 PM
deucekid's Avatar
will rub on upper a-arms, and spacers are always a bad idea. puts too much stress on the studs
