tire psi?
Old Nov 15, 2010 | 11:55 PM
robinson314's Avatar
tire psi? Nitto's
just order Terra Grappler LT285/70/17 load rating E. Max psi is 80lbs per Nitto. Didn't know if any is running these and at what PSI. Seems that 50-55 psi for normal driving conditions should be ok after doing some searching. Any help would be good.
Old Nov 16, 2010 | 07:01 AM
kingfish51's Avatar
You shouldn't need anything higher than 50, even loaded. If you go lower, don't go below 45.
Old Nov 16, 2010 | 12:01 PM
Derrick@TireRack's Avatar
Former Sponsor
45psi seems to be the norm for most guys running that size. Kind of depends on the ride you want to get. I would start there and then adjust up or down depending on the ride you want.
