Trail Grappler 295/70R18 on stock rims... control arm rubbing
So I got my new Nitto Trail Grapplers in 295/70R18 last week... there on the stock 18'' lariat rims. I love the tires, not to loud... but....
At full lock I've got a rub on the control arm. No other rubbing, but I'm trying to figure out if there might be a way to correct this. I know alot of people with say "your either gonna rub on the wheel well or the control arm with just a leveling kit"... but hey we can try right?
Only thing i can figure that might work is a wheel spacer... uck
Anybody else had this problem running a leveling kit and 35's with control arm rubbing you were able to fix it? Thanks
If its rubbing just on the lock to lock, other then the obvious of not turning that far, you can put a steering limiter on the vehicle that will stop you from turning to far. Either way, you get the same result. Just one of the perks for going big!!
