Question about a 2006 2wd leveled
Had this same truck with nitto terra grapplers 295/70/17 on ultra 17x8 w/25mm offset. worked perfect. looked at getting the same tire with a 17x9 w/12mm offset. am i correct in thinking these will stick out more (which I want) due to the offset? Since this rim is 1" wider will this potentially cause that tire to rub or will the difference in offset pretty much be a wash due to the fact that the rim is going to stick out more? Thanks.
just found out they have the 17x9 in a -12mm offset too. still dont know the bs though. The -12mm offset would push out the wheel/tire to allow more room for the 295/70/17 correct? Think this combo would work ok?
just called your site looking for some mamba m3's and terra grapps in 295/70/17. guy said you dont deal in nittos. looking to make a package deal on that combo in a week or so. can you help a guy out?
17x9 -12mm is 4.5" bs
17x9 +12mm is 5.5" bs
how far will the -12mm wheel stick out with a 295/70/17 terra grapp?
thanks.
thanks.
A 9 inch wheel with 4.5 inches of BS will stick out 2.5 inches farther than the OEM wheel.
A 9 inch wheel with 5.5 inches of BS will stick out 1.5 inches farther than the OEM wheel.
A 8 inch wheel with 5.5 inches of BS will stick out 0.5 inches farther than the OEM wheel.
thinking bout going with a 17x8.5 +25mm 5.71" bs on a 295/70 terra grapp. would this combo basically keep everything in the stock location
