Brake Issue ABS
Old Oct 7, 2010 | 07:10 PM
StuckInUT's Avatar
Brake Issue ABS
Ok, for starters I have a 98 F150 ext cab, 5.4, 4x4, with 115k on it. The other day when I was headed home from work when I went to stop the brakes locked up, not sure if it was all or just one wheel, I wasn't braking hard or anything out of the norm. Now the E-brake light is on and the ABS light is on. The pedal feels normal, not any softer or harder than it normally does. Im going to go get the codes read and new pads tomorrow, as it is about that time anyways. Is there anything else I should be looking for while doing this job that may have caused this? Any input/help or advice is greatly appreciated.
Old Oct 8, 2010 | 01:35 PM
mkosu04's Avatar
sounds like a speed sensor went bad.
Old Oct 9, 2010 | 02:49 AM
StuckInUT's Avatar
Ok thanks, I'll make sure to find that and check it out as well when I am in there.
