Will this fit with no rubbin?
Old Aug 17, 2010 | 11:32 AM
Northerner's Avatar
I am thinking about going with a 20x9 wheel with +18 and 5.71 BS. I would like to go with a 35x12.5x20 tire. Probably a Toyo M/T. I have a 2006 F-150 FX 4 with a 2.5in leveling kit and an extra leaf spring out back. Will this setup rub, can I fit it, any better suggestions?
Thanks guys!
Old Aug 17, 2010 | 12:47 PM
wandell's Avatar
Yes, they will rub. Either add more lift or go with a 33 inch tire.
Old Aug 17, 2010 | 01:16 PM
Northerner's Avatar
How much cutting involved? Do I even want to go there, is it worth it?
What would be the best tire with this package if you think the rubbin issues will be a problem?
I currently have 285/65/20 on the truck and it looks OK, but the tires just seem to tall and not wide enough on the stock ford 20" rim. So with the new wheel dimensions above, what would be best:
a 34/11/20, which might look just as goofy but may be ok with the new wheels?
or
a 33/12.5/20?
would a 33 in tire look to small with the 2.5in leveling kit and leaf spring?
Old Aug 17, 2010 | 01:52 PM
UNC Lariat's Avatar
It seems most people with a leveling kit and aftermarket rims go with 33x12.50 or the 305/55/20 (almost the same size) and fit with minimal rubbing. The tires look proportional and really good IMO.
Old Aug 17, 2010 | 01:54 PM
mdhawkin's Avatar
I dont think a 33" would look too small with only a leveling kit, the wheels are whats hurting you here.
Old Aug 17, 2010 | 02:07 PM
Northerner's Avatar
Yeah, I agree, I need some new wheels. The ford stock 20" were great initially but I need something new.
How far will these stick out of the wheel well with the 33x12.5x20?
Is this a good way to go?
Old Aug 17, 2010 | 02:26 PM
AZFX4's Avatar
They wont stick out very far. Im rinning the same specs on a 18x9 with a 295/70/18 tire. Check my pics to see how they look.
Old Aug 17, 2010 | 02:35 PM
Northerner's Avatar
I would like them to stick out just a little farther than that. not much though...
Old Aug 17, 2010 | 10:29 PM
wandell's Avatar
Those wheels will stick out about 1 1/4 inches farther than your OEM wheels.
