***33 inch tires on leveling kit question!!!***
Old Jul 22, 2010 | 02:13 PM
PBartKR08's Avatar
Hey, I'm a new comer to this forum and I've got a question! If someone could give me some info it would be great! I have a 2007 King Ranch Super Crew with a 6 1/2 foot bed. I just put a leveling kit on it and I was wondering if these tires I have on order will fit for sure! I just order 20x9.5 inch rims and I'm putting 305/55/20 Pro comp XTreme's on them... Will These Tires rub anywhere(even when cutt'n the wheel all the way! If You Could Help Me Out It Would Be Much appreicated! Thanks
Old Jul 22, 2010 | 02:16 PM
PBartKR08's Avatar
And does anyone know if i would need to buy fender flares to cover the tires? Maryland State law says the tires must be covered if they stick out past the orignal fenders! Thanks again
Old Jul 22, 2010 | 04:08 PM
05BlackFX4's Avatar
for reference check my gallery....I have 20x9 with +18MM offset....the offset is what is going to tell you how far they stick out. More negative offset will stick out further. The tires will not rub, I have a 2" Autospring leveling kit and no trimming is required, also no rubbing at full lock in forward/reverse.
You will be happy with your set up
Tires stick out slightly more than stock depending on your offset.....You may want to get a set of fender flares, its really your choice.
Old Jul 22, 2010 | 08:20 PM
wandell's Avatar
Right. The combo will fit, but we can't tell you if there will be any rubbing or how far they will stick out without knowing the backspacing.
Old Jul 23, 2010 | 11:46 AM
PBartKR08's Avatar
Ok Thanks Guys, The offset I'm getting is a -6... so i'm guessing they'll stick out some... Thanks again!
