Autospring 2" Leveling kit
Old Jul 17, 2010 | 05:06 PM
JHause22's Avatar
Do I need new shocks and bushings if I add this to a Stock 07?
Old Jul 17, 2010 | 07:42 PM
07_FX4GUY's Avatar
Most of the time the answer is no, but it depends on how many miles are on ur current struts as well as your driving style and amount of off roading you do. If the ball joints are worn when you get in there to put on the leveling kit you might as well change em out.
Old Jul 17, 2010 | 07:52 PM
Carolinaboy32's Avatar
I have a AS 2" Leveling kit for sale if you're interested PM me if you're interested
Old Jul 17, 2010 | 09:13 PM
JHause22's Avatar
Its got 34000 on it and I havent done very much off road driving with it since I bought it brand new off the lot. I just didnt know If I really do need longer shocks to install the kit. Thanks for your help.
Old Jul 18, 2010 | 07:13 AM
svt2205's Avatar
The spacer type leveling kit does not require that you get a longer strut. But something to consider, Ford struts/shocks are junk to begin with. If your adding a leveling kit to make room for a larger (heavier) tire. You may want to consider upgrading your struts/shocks for better control of the added weight.
Since you need to pull the spring/strut assembly out for the leveling kit, it is a good opportunity to swap in new struts or any other front end part that may be weak. I would recommend you have someone swap over the springs on the struts if you're not familiar with working with loaded suspension components. It's just safer and eaiser.
Old Jul 18, 2010 | 11:06 AM
Maxout05's Avatar
If your going to go through all that your better off getting a strut with the lift built in. Like the rancho qwik lift, or the much better way to go being the bilstein kit.
But to anwser the op's question, NO you do not need new shocks/struts, and there isnt any bushings to replace when concerning a leveling kit.
I had 36,000 on my 05 when i did the a.s. kit and i drove it to 60,000 with no issues. All i did was add the a.s. 2" kit, in my yard i might add.
