6.5 inch lift tire size
First, if you use a 3 inch coilspring spacer you will need longer, aftermarket upper control arms to get the alignment within specs. 2 inches is the limit for a spacer (or a lift coil) with the OEM control arms.
With 5 inches of lift, I'd go with a 33 inch tire on an 8 inch wide wheel with 4.5 inches of backspacing. If you go higher than that (maybe add a 3 inch body lift also?) I'd start looking at 35's.
