Rubbing Issue
Old Jun 22, 2010 | 10:29 PM
330CID 05F150's Avatar
Question Rubbing Issue
I have a 2005 F150 Supercrew with a 2" Autospring leveling kit. Just put a set of Mazzi Hulk 20x10 wheels with Nitto A/T Terra Grapplers tires 305/55/20. I am having some rubbing issues with this setup. I have screwed the front fenders in a bit using a screw and treaded clip, it is not as bad but still rubs especially in reverse. Has anyone else had the problem and what else could I do rather than cutting the fenders back?? Any help is greatly appreciated. Thanks in advance.
Last edited by 330CID 05F150; Jun 22, 2010 at 10:37 PM. Reason: Forgot to add about my leveling kit
Old Jun 22, 2010 | 10:52 PM
wandell's Avatar
Your rubbing is caused by your wheels. They are 10 inches wide with 4.5 inches of backspacing (I believe). If you go to a 9 inch wheel with 4.5 or 5 inches of backspacing, it will eliminated the rubbing. If you don't want to change wheels, you can do some trimming or add more lift (like a 3 inch body lift).
