Tires For 2004 F150
Old Jun 16, 2010 | 10:37 AM
goosehunter's Avatar
Tires For 2004 F150
Alright heres the deal, question probably has been aswered many times before but I can't find the answer. I have a 2004 F150 extended cab. I have the 2-1/2" leveling kit in the front rest is stock. I am looking at the Hankook dynapro MT tires and trying to figure out what size I can get in there on stock rims. So far the only ones I am sure will fit is the 285/70/17. What other sizes will typically fit under this setup. Thanks in advance.
Old Jun 16, 2010 | 11:52 AM
wandell's Avatar
If it's a 4x4, you can fit a 35x12.50 using the OEM wheels with only minor rubbing on the control arms at full steering lock.
If it's a 4x2, I'd stick with a 33 inch tire like the 285/70-17's or 305/65-17.
Old Jun 17, 2010 | 07:45 PM
Thanks for the help. I ordered Hankook Dynapro MT's-315/70/17's. It is a 4x4 as well. I am hoping I won't have too much rubbing. Should be in in about 5 days. I will try and post some pics once they are on.
Old Jun 17, 2010 | 10:36 PM
wandell's Avatar
Like I said, it's minor rubbing on the contol arms at full steering lock using the OEM wheels.
