Help! Can I fit it?
Old Apr 18, 2010 | 10:52 PM
jackdupford's Avatar
Help! Can I fit it?
So my buddy is going to give me a good deal on some 35x13.5x20 mickey thompson atz's
Here is the problem: I have an f150 with a rough country 2.5 in leveling kit in the front and a 1" block in the back. Rough country reccomends 35x12.5
Do you think I could fit 35x13.5? does it matter what the backspacing is on the rims? I mean does the extra inch of width really make a difference? because i was gonna get 35x12.5 with a 10 in wide rim anyways..
Thanks for all of your replies!
Old Apr 18, 2010 | 11:26 PM
Dog'em's Avatar
A 13" tire on a 10" rim with only a level kit ................. I think you are just asking for trouble. The tire will be okay but the rim will give you fits, what backspace do they have ?
Old Apr 18, 2010 | 11:27 PM
mdhawkin's Avatar
Do you think I could fit 35x13.5? does it matter what the backspacing is on the rims? I mean does the extra inch of width really make a d/ifference? because i was gonna get 35x12.5 with a 10 in wide rim anyways..
It does matter, in order to accommodate 35/12.50/XX you typically have to stick to a wheel close to the factory specs BS (5.5). However with a factory rim or one with similar specs I dont think you could get that tire on as its width would cause it to hit the UCA. The solution would be to go with a different BS/OS, in doing so you will end up having some rubbing issues. Not saying you can not run them, but expect rubbing and some trimming.
Old Apr 18, 2010 | 11:28 PM
I still have to buy rims, so any....
So with just a leveling kit which claims i can fit 35s means i can fit 35x13.5?
Old Apr 18, 2010 | 11:32 PM
mdhawkin's Avatar
Notice I said fit a 12.50, not a 13.50, a rim that would allow you to cleanly run a 35x12.x50 will not accommodate a 13.50, the tire will hit the UCA during installation. Like I said you can probably with the right wheel get them on there, but expect some trimming and rubbing.
Old Apr 19, 2010 | 09:29 AM
ChrisAU's Avatar
I doubt you will be able to fit a 35x13.50 on any rim with just a level without significant rubbing somewhere.
Old Apr 19, 2010 | 10:40 AM
wandell's Avatar
I agree. YOu are gonna need more lift, but i't hard to give exact info without knowing what exact truck you have.
Old Apr 19, 2010 | 11:15 AM
radar's FX4's Avatar
def sounds like you need more lift than the leveling kit.
