Rotors for 24" Wheels
Old Mar 30, 2010 | 12:00 AM
thenewbreed's Avatar
So my rotors are warped,,,AGAIN!!! I had them swapped out at the end of 08 so not so bad I guess. I think I should upgrade to something bigger because of the 24" wheels. I have not changed my own brakes since my 02 F150 though. I did read FX4 chicks How to and it seems like nothing has changed. I want to replace the front and rear. Any suggestions on rotors/brakes and tips I should look out for.
Old Mar 30, 2010 | 12:28 AM
well you could step into a "Big brake" kit but those usually run 1500-2000 an axle, since you get brackets, calipers, lines, rotors, and pads
And i dont even know if anyone makes a big brake upgrade for the 04+ trucks yet
Old Mar 30, 2010 | 12:46 AM
Ah dang well I cant do that. I only have about $300 to spend. So in that case what regular aftermarket rotors do you suggest. I know Autozone sells the Duralast Brand rotor for $82 each but they aren't slotted or anything like thaat.
Old Mar 30, 2010 | 09:10 AM
I bought the brakes for my red truck through Latemodelrestoration.com and they are powerslot brand, very high quality, check their website and call Lee. He's 87fiveoh254 on here he can get you hooked up on a set.
