Possible to balance with non-removable center caps?
Is there a machine, adapter, trick, or some sort of self balancing compound that can be used when a center cap can not be removed? Thanks.
Yea, I could score around the center caps and knock em inward or just destroy them and order some new ones which would probably be more ideal...they are cheap, but look like crap after only a few months. I'm working on an alternative solution first however. The ride is fine, but want to make sure the components aren't taking a beating.
http://www.innovativebalancing.com/
Several guys on the Ranger forum I was on used Dyna Beads or plastic airsoft pellets with good luck...
