smaller spare?
Old Mar 13, 2010 | 08:38 PM
jmos26's Avatar
smaller spare?
I have a 2006 screw 4x4 with 295/70/17 Nitto Trail Grapplers on it. Can I run an all terain spare that is 285/70/17. I know its smaller but will it do any damage to run it for a bit? If so how long can I run it?
Old Mar 13, 2010 | 10:10 PM
bnuts's Avatar
i was wondering whats the biggest tire that will fit under the truck also
Old Mar 13, 2010 | 10:12 PM
Galaxy's Avatar
No damage. That's not small enough to make any difference. If you want to feel better about it though, put the spare on the front. Then you have nothing at all to worry about and can run it indefinitely...that's what I'd do.
If you need to ask, you don't run different diameter tires on the rear axle due to the LS. You don't want the two wheels trying to turn at different speeds...which is what will happen with two different diameter tires on the same axle. Front doesn't matter at all as long as 4WD is not engaged since each side is freewheeling.
Old Mar 14, 2010 | 07:13 AM
ryan42680's Avatar
X2 ^^^
Old Mar 14, 2010 | 11:42 PM
AZFX4's Avatar
I have a 35inch tire in my stock spare location.
