Rim Width. 8.5 or 10
Old Feb 25, 2010 | 01:35 PM
Ferg's Avatar
OK. I can't get the search function to work for me right now and I need info quick.
I'm looking at the 20" Rockstarts with a 305/55/20 tire. 33x12.5x20
They come in the 10" and 8.5" width.
I have a 2.5 HBS leveling kit on my 4wd FX4 (2004)
Any idea on if the 10" rim will work? Or should I stick with the 8.5"?
Also, how much differece in appearance is there with the 1.5" rim width difference?
Thanks for all the help.
Old Feb 25, 2010 | 01:39 PM
russ10screw's Avatar
I have an 02 FX4 and have a 305/55/20 around a 20x10 wheel. If you like a wide aggressive stance, go with the 10". I can't imagine you'd have much trouble with them since you have the leveling kit. What is the backspacing on those?
Old Feb 25, 2010 | 02:02 PM
Ferg's Avatar
The 20x10's are 4.5"
The 20x8.5's are 6.13"
Old Feb 25, 2010 | 03:12 PM
Well based on that, I believe the 10" wide wheel will stick out 3" further than the 8.5" wheel (~1.5" of less backspacing, and an extra 1.5" of width). I think that would still work though with the leveling kit and 33's. Wandell is the guru and hopefully he'll chime in soon.
Hope I've helped a bit.
Old Feb 25, 2010 | 09:40 PM
Ferg's Avatar
ended up ordering the 8.5" with 10mm offset. stick out about 1.3" further from stock.... can't wait to see em:-D
Old Feb 25, 2010 | 10:04 PM
wandell's Avatar
The 8.5's will stick out about 1/2 inch farther than your OEM wheels and the 10's would stick out 3.5 inches farther than your stock wheels.
Old Feb 25, 2010 | 10:47 PM
Ferg's Avatar
Are you referring to the 35 mm offset wheels?
not sure if this has been seen before, but www.wheelsmaster.com has a good offset program to compare wheels.
I believe I'll be about 1.5" out with the 10mm offset
The 35mm offset shoudl be 0.5" out from OE.
Old Feb 26, 2010 | 12:07 PM
wandell's Avatar
I went by the BS measurements you posted
