Clunking niose in my Front driver tire
Old Feb 19, 2010 | 10:31 PM
SaintsFanF150's Avatar
It Started off as a squeking niose when i make a slow right turn ...now i can hear it ..clunk..clunk..clunk
I tightened my lugs..idk
Old Feb 19, 2010 | 10:32 PM
2004 F-150 Supercrew
Old Feb 19, 2010 | 10:40 PM
Paralyzer's Avatar
balljoints, tie rod ends, sway bar end liks, loose caliper, loose wheel bearing, worn bushings...many possibilities!
Old Feb 19, 2010 | 10:52 PM
whackemnstackem's Avatar
ive had this happen twice. personal experience would have me say its either a loose brake caliper or a screw in your tire.
Old Mar 18, 2010 | 07:37 PM
It turn out to be my lower ball joint....tire shop whats $832!...i think ill do it myself
Old Mar 19, 2010 | 02:17 PM
wcperryman's Avatar
Lower ball joint?
I recently thought I had the same problem.
Turned out to be wheel bearings.
But from what I understand lower ball joints are the easy ones.
The upper ball joint is the one that's going to give you trouble.
Or I could've gotten them mixed up, but I'm pretty sure.
