TPMS sensors in 2010 F150...How to Install, What do I need?...Help...
Old Feb 19, 2010 | 12:14 PM
SlvrBrute's Avatar
Hey Guys, I have purchased a set of aftermarket wheels and tires to run in the summer time for my 2010 F150 FX4 and I need to know what all I need to reinstall the TPMS sensors? I am going to buy a new set of sensors and leave the other ones in my stock 20's that came with the truck because I am running that set in the winter. I can buy a set of the sensors but I don't know how they go on because they are the valve stem type but I would think there should be something else to hold them on the wheel besides just screwing on the valve stem? Hopefully somebody with an 09-10 has dealt with this because I know that they have different sensors than the 04-08's do and I want to make sure I get everything and also wanted to know if there is a way to get chrome valve stems? Any help would be appreciated.
The wheels are 20x9 Ballistic Wizards and the tires are BF Goodrich All Terrains that will be going on the truck if that info is needed.
Old Feb 19, 2010 | 12:40 PM
kingfish51's Avatar
If you buy the sensors as a kit, they come with new valve stems. Otherwise, you can buy the valve stems separately. You will also need a reset tool to reset the sensors when you switch back and forth.
