Do I Need To Bleed?
Old Jan 29, 2010 | 01:47 PM
mhockey9090's Avatar
Do I Need To Bleed?
Hopefully soon when all my parts come in ill be installing my 12inch Rize and was wondering when i change out my brake lines should i bleed them? Would it be a good idea or no? Few people said ill have to add about a pint anyways due to have longer brake lines etc. Truck has 50k on it
Old Jan 29, 2010 | 01:55 PM
4.2trimble's Avatar
yes blead them when you install the new lines
Old Jan 29, 2010 | 01:58 PM
Alright cool thanks man. What brand of fluid should i use?
Old Jan 29, 2010 | 02:12 PM
4.2trimble's Avatar
i used the cheap DOT 4 stuff.
autozone brand. not sure if theres much difference for brake fluid.
Old Jan 29, 2010 | 02:25 PM
oh ok sounds good
Old Jan 29, 2010 | 02:51 PM
mkosu04's Avatar
You should be using DOT 3. The OEM uses DOT 3... some DOT 4 fluids may be incompatible.
The additives in brake fluid can vary. I would stick with name brands if it were my truck. Cheaping-out on brake fluid could lead to higher wear or even rust in the brake system. Generally not a system where you want to take risks.
