need help please best way to fit 35s on 01
i have an o1 expedition i want to put 35s on it whats the best way other than suspension lift a 3 inch body kit or coil spacers ?? it has adjustable pedals any help at all would b very welcome thanks again guys
If it is a 2wd you'd need about 6" or more of lift with the right width tires and right rims. I'm not sure if they make suspension lifts that big for expos. You'd probably be best off going with a small suspension lift like a combo of lift springs and spindle lift up front and a block or lift leafs in back with a body lift.
If its 4wd I've seen others with just a 3"bl and 35s. 2wd id say you could get away with 6 or 7 inches of lift for 35s with the right backspacing. If your 4wd id run cranked tbars and 3" bl and if your 2wd id run 3" bl and 3.5" lift spindles if your wheels have the right backspacing.
its a 4wd and how 33s look
33's will look better at stock height in my opinion. If you want to fit 35's, the best way is to crank up the torsion bars all the way and use the OEM wheels.
It would be tight with just turning up the bars, but doable. Here is mine with 33s at stock height.
http://i35.photobucket.com/albums/d1...S/DSCN0779.jpg http://i35.photobucket.com/albums/d1...S/DSCN0781.jpg http://i35.photobucket.com/albums/d1...S/DSCN0782.jpg http://i35.photobucket.com/albums/d1...S/DSCN0785.jpg To be honest if you go much bigger than 33, you should look at regearing. |
i dont mind doing a body lift i lovethe look with 3 inch bl and 35s howsluggish is yours with the 33s
It is not terrible, I went from the factory 32s, to 33s so it wasn't a huge jump. YOU can definitely tell a difference. IT kicks out of overdrive on fairly minor grades, more so than it did before., and I also saw drop in mileage around town, to teh tune of about 1mpg.
ok thanks again i like the look of your truck i just wanted it to b lil higher i may give what you have a try or get a body lift
3" BL with 315/70/17's or equivilent looks really good if you have stock 17" rims too.
i really want the pa 3 in bl but my truck has adjustable pedals local shop says it dont fit with the pedals but pa says it can b done pedal assembly just has to be bent i dunno any one have experience with this
I have adjustable pedals. I've also installed one on a friends Expy with adjustable pedals. It is not an issues. Your local shop gave you some misinformation.
ok thanks but info was coming straight from pa they said there is an issue only when the steering extension touches something his exact words were it will light your dash up like a xmas tree lol but its good to hear it can b done with out any problems would love to see your trucks thanks again for all the help
