biggest tire size?
biggest tire size?
i know this has probably been answered a million times but what is the biggest tire size i can fit with no rubbing (or cutting) on my 2wd with a 2" leveling kit? on a 20" wheel if that makes a difference. and what backspacing should i get on a wheel? sorry im such a noob about this kind of stuff
Edit/Delete Message
Edit/Delete Message
Search?
I think the biggest you can go on a 4x2 with a 2" level is a 33" tire. You might be able to fit a 35" depending on what wheel you go with, but I don't know for sure.
As far as backspacing, do you want your tires to stick out, or not?
- NCSU
- NCSU
