Shake when Braking
Old Jan 17, 2010 | 07:16 PM
FordRepeater's Avatar
Shake when Braking
I have an 04 f-150 supercrew 5.4 4x4 and when I brake hard I can feel the truck shake some. It can be pretty bad when going down hills at higher speed. I have replaced the front discs and pads twice but the shake is still there. Any help would be greatly appreciated.
Old Jan 17, 2010 | 07:55 PM
RandomHero34's Avatar
i would say your rotors are warped.
Old Jan 17, 2010 | 07:57 PM
alex7191's Avatar
You replaced the rotors and the same shake is still there?? what you're describing sounds just like a warped rotor to me
if you don't torque your lugs evenly i believe rotors will warp? but im not positive. it does make sense though
Old Jan 17, 2010 | 08:50 PM
Should I replace the rear rotors??
