Need tire size help
Old Jan 14, 2010 | 08:07 PM
mludi's Avatar
Need tire size help
I have 275/70/18 on stock 18x8 rims. I don't want to go much wider but would like to go about an inch higher. This is on a 2006 f250 supercrew (no lift or level kit) an ideas??? Thanks
Old Jan 14, 2010 | 09:52 PM
wandell's Avatar
If your truck is a 4x4, I'd suggest the 305/65-18 BFG AT KO which is essentially a 34x12.50 tire. If you add a leveling kit you can fit a 35x12.50-18 (305/70-18) using your OEM 18x7.5 inch wheels but they will rub slightly on the control arms at full steering lock.
Old Jan 15, 2010 | 08:23 AM
mludi's Avatar
Thanks wandell!!
