Tire Sizes On Stock 2010 F-150 4x4
Ok thanks. I thought this would be a simple question my Goodyear dealer could answer but I checked with three dealers in town and to my amazement none had installed these tires on the new F-150 (09-10) with 20's. They had done several with 18's.
Tires on stock rims
Hi guys, First post...........I have a 2010 fx4 screw that came with 275x65x18's stock. I installed a 2" leveling kit. So that size tire on a fx4 18" rim is now stock. I now would like to go taller to fill in the wheel well. I'm thinking 275X70X18 which are around 33.2 or so. I saw a 350 with them, are they stock for a 350 ? and will they work out ok with mine. The 285x65x18's are shorter. Thanks guys
Yes. In fact you can fit up to a 35x12.50 using your OEM wheels. But they will rub the control arms at full steering lock.
actually a 275/65-20 is a 34" tire which is 2" taller than stock. You could run a 275/60 (33") and be fine, or even a 305/55 (also a 33")
