18X9 on 33.5x13.50?
33.5x13.50 on 18x9?
Will these fit without sticking out too far? The backspacing is 5.47 with a -12mm offset. The tires are 33.5x13.50x18 with a 3" lift.
http://www.4wheelparts.com/Wheels/Mo...MO95889063312N
Those wheels will stick out about 1.5 inches farther than your OEM wheels. A 33x13.50 will fit your truck if you have a 4x4. If it's a 4x2 you will have to do some trimming or choose a narrower tire.
Haha sorry, I guess I should have specified. The truck is an 04 FX4, and I already have the lift and those tires (Terra Grapplers) but they're on the stock wheel. And they don't stick out at all really. I think 1.5" might look kind of good. What do you think of the wheel I chose? Have any other suggestions?
I think I've decided to go with these instead
http://www.4wheelparts.com/Wheels/XD...PXD77889067718
5.71" offset, and 18mm of backspacing.
I understand offset, but what will the backspacing affect? That offset and bs should still give it a good 1.5" out right? I like the wide look, but not too wide.
you might want to consider running a 12.5" width , b/c i have a feeling 5.71 backspacing and a 13.5" width tire is gunna rub on the control arm, especially if your gunna run a mud tire with large side lugs.
wider wheels would make the rubbing worse, and i dont think its good to run a 13.5 width tire on stock wheels. Most people say 12.5 width is pushing it on stock wheels
Well, we'll see what happens when I get home and throw em on. The tires on my truck are brand new, so I'd hate to replace them already. But if I have to then I guess I will. If it comes down to that, can't I fit like a 35x11.50 with 3 inches of lift?
