front wheel locked up
Old Dec 22, 2009 | 11:07 PM
lordfeyr's Avatar
So a little history... a couple months ago my passenger wheel sheared off and the front of the truck dropped to the ground. I ended up replacing a rim, wheel hub and bearing and lower ball joint.
Fast forward to today. I took a trip to show some christmas lights to my kids and when I was exiting the freeway and coming to a stop it felt like I hit a washboard. I went around the block and when rolling everything seemed fine until I hit the brakes and it did it again.
I looked and cannot find anything loose. I had my wife put the truck in drive to get it to roll so I could see what was going on and the truck did not move. She gave it gas and I watched the front wheel skip. Kind of like it was locked and the teeth gave way.
Do you think the new hub is bad? What else could it be? Abs? Iwe?
Old Dec 23, 2009 | 03:01 PM
lordfeyr's Avatar
OK so apparently I over reacted
I pulled that corner apart today and found that one of my caliper bolts had backed out and came off. This caused the caliper to swing and basically lock against the rim which caused the skippings.
Luckily there was no real damage done. I was able to get a new bolt and re-installed and put some blue loctite on there so this doesnt happen again.
Old Dec 24, 2009 | 06:41 PM
smoke stained's Avatar
I had about the same thing happen to me a few days ago. my wheel didnt lock up but it was making awful noises and i could hardly back up. i took the wheel off and the caliper nearly fell off.
Old Dec 24, 2009 | 06:45 PM
f150fella08's Avatar
that happened to my ranger i had...the caliper rubbed a hole in my wheel i took all the caliper bolts out and put loctite on all of them and tightened the crap out of them
