looking for wheels
looking for wheels
i was looking for some wheels and came across some xd series hoss in a 17x9 for 5x135 pattern with -12 offset and was wondering if anyone knos where to get hub centric adapters because the wheels are not hub centric and i cant find any other wheels i like? manufactures need to get it together and make more wheels for our pattern!!!
I dont think that it really matters if the wheels are hub centric or not, unless it is just a personal preference.....As long as you get the bolt pattern correct for your make and model and know what backspacing you are wanting to use, thats it. Manufacturers have made plenty of wheels to fit all makes and models. I think most aftermarket wheels are Lug Centric instead. Anyway good luck to you, hope that helps
Here are a few ive found.. I assume you had the 97-03 body style f150...but these all show them in a 17 inch wheel 5x135
.http://www.rimzoneonline.com/xd79517x9hosschrome.htm
http://www.bigwheels.net/?location=w...del&model=Hoss Chrome 795
http://www.sfxperformance.com/parts/...579013212N.htm
thats odd i wonder why 4 wheel is claiming not hub centric and sfxperformance is saying they are??? i talked to my wheel shop and the guy advised me not to get them due to it could cause balancing problems and could cause vibrations in the front end. he said he even called the wheel company and they told him the wheels are no good. i really want these wheels is anyone else running them on the same truck as me???
If i were you id try another wheel guy. The last website says they are hub centric. You probably should call KMC directly if you want to know for sure.
Wheel Pros is the exclusive distributor of KMC Wheels.
877.943.3577
877.943.3577
i called 4wheelparts and the guy said the wheels were lug centric and that there was no need for a hub centric spacer is this true or do i need the spacer i need some enlightenment guys?
I also matched the part numbers to 4 wheelparts and sfxperformance they are the same so one is wrong on claiming hub centric or not.
