2007 Fx2 Front ABS Sensor question
Old Nov 15, 2009 | 09:46 PM
kgalight04sb's Avatar
Question 2007 Fx2 Front ABS Sensor question
I have a strange issue i'm hoping someone might be able to shed some light on. 2007 F150 2wd Fx2.
try to make a long story short:
* Replaced both front rotors awhile back, ABS still worked fine.
* Recently had a problem with left front, removed rotor, but put it back on with new pads
* Dropped caliper in process, ABS wire helped break the fall, rotor never hit the ground
* ABS light came on and stayed on after putting it all back together, i assumed i damaged the wire
* Purchased new ABS sensor from ford
* Installed new sensor, ABS light now off, but ABS activates as soon as you touch the pedal at very low speeds, ABS light never comes back on as a note
* Pulled both front sensor's, cleaned, cleaned ABS notch's on both rotors, pulled +/- battery cables for 10minutes 1st time. then disconnected negative cable only for 2 hours.
* Tested both sensor's with ohm meter, both have same exact resistance readings
* problem still persists - anyone have any ideas?
Thanks in advance!
Old Nov 16, 2009 | 07:08 PM
elcamino's Avatar
Maybe exhaust
Hi,
I have a 07 FX2 with a magaflow exhaust. My ABS light would come on when I had some weight in the bed. Turned out the exhaust had burned the wires and the Ford dealer charged me $150 to fix.
