Before/After pics kumho at's
thanks man that means alot!! and no its a 2wd lol. but as soon as i have the extra money its gonna have 265s/ then a leveling kit
i think you should beable to fit a 285 right?
yeah, i could. ill get the 285s if i go with 2 inch lift coils. the only problem is that i don't know if that will extend my shocks too much.
how much are your t-bars cranked?
the lift coils will probably be too much for your stock shocks but you can get some longer ones for about 50 bucks.
I agree with jake and it would be fairly cheap for new longer shocks....cause i think your truck would look incredible with 285' on it! I think you'd be happier with 285's over 265's too.
a couple inches but it's just the stock keys which i think basically keep you from crankin them to far......might lower it a lil just cause i have tons of room when truning the wheel.
thanks man
i do too
Man you dont even need a lift/leveling kit or anything to run 285's on your truck. As long as you keep the OEM wheels then you MIGHT rub on the sway bar(I think that is what its called). I ran 285's on a stock 2wd for a year and a half before I did anything to it. My truck rubbed on the sway bar at full steering lock which I usually never turned far enough to actually make it rub. Only time I rub really was backing down hills and such. Go with 285's and a $40 daystar like Jake is running if you are worried about them rubbing at all.
