08 expy oem 18" tire size help
Old Oct 10, 2009 | 02:20 AM
bewtew's Avatar
Hi All,
My TPMS lit up today and found out that one of the tires had its sidewall crack. Since all are almost bald/bad anyway, i was planning on replacing them tomorrow. Question is I would like to know what's the biggest tire combo that would work. Currently, I have the 18" 7-spoke chrome-plated stockers wrapped in 255/70/18 (32.06") and was checking out the following sizes:
- 265/70/18 (32.61")
- 275/65/18 (32.07")
- 275/70/18 (33.16")
- 285/60/18 (31.46")
- 285/65/18 (32.59")
Ideally, I would love to get the 285/65/18, but not sure if it will rub. My alternative is 285/60/18 (terra grapplers which i got quoted for $1080 inc. mount/balance/valvestems/warranty/freerotation), but was wondering if it might look somewhat small.
I'm also considering temporarily using my 05 F150 (oem) wheels wrapped in 305/55/20. Will this fit on an 08 expy?
Thanks!!!
Old Oct 10, 2009 | 10:11 AM
wandell's Avatar
Yes, every size you listed will fit. The 305/55-20's my look the best.
Old Oct 10, 2009 | 01:15 PM
bewtew's Avatar
Thanks Wandell!!
Edit..
Just purchased BFG AT 285/65/18. 4WP set the PSI to 65 (max. is 80). Any suggestions as far as what i should set it to? The expy is currently my DD.
Thanks again.
Old Oct 10, 2009 | 10:17 PM
wandell's Avatar
I'd run 40-45 for daily driving.
Old Oct 11, 2009 | 05:51 AM
bewtew's Avatar
Thanks! Any idea why my TPMS indicator lamp stays on?
Old Oct 11, 2009 | 07:30 AM
kingfish51's Avatar
I would not go any lower than 45 for day to day driving. And if towing, bump them up to 50 to 55.
How far have you driven since tires were replaced? Another problem may be that the sensors were only made to handle a max pressure of 50. You may need to get sensors made for a load range E tire.
Old Oct 11, 2009 | 08:46 AM
wandell's Avatar
I thought the TPMS only detected low tire pressure? One could have been damaged during installation.
Old Oct 11, 2009 | 10:29 AM
kingfish51's Avatar
It is not detecting too high a pressure, it is rated depending upon they OE tires on it. The sensors on my 07 were rated to 50 psi and the OE tires on it were p series with a max of 35. Also available were LR C tires with a max of 50. Not sure if the Expy sensors are rated the same. Also a LR E sensor would be set to turn on the light at 46psi, as compared to the P series or LR C which would turn it on at about 28.
Old Oct 11, 2009 | 10:50 AM
blueovelboy's Avatar
do you have the system in instrument cluster or is it ( the tpms) in the console? the one i have is in the counsel and when you put the tires in a different spot on the truck you have the recalibrate it to the tires new location. but thats all done thru the on board computer just have to reset it!
Old Oct 11, 2009 | 05:11 PM
bewtew's Avatar
Thanks for the response guys. I think I'll keep the psi around 45-50.
I'm really thinking the sensors were specific to the OE tires - it can only detect so much of a pressure, although I really hope that none is damaged. When I purchased the tires, I actually had one test-fitted (to make sure no rubbing) on the tire that had the crack/slit on the sidewall, which I assume to have caused the TPMS to go off in the first place. I was watching the whole time from demounting to mounting/balancing and the tech was careful. When the tech finally placed the wheel on the vehicle, he asked me to start it and that's when I noticed that the indicator lamp and console message were still on. So, using this logic, it's possible that the other tires may have caused the TPMS to go off.
Anyway, I've driven about 10mi w/ the new tires. I've tried resetting the message, but that only rids of the console message; the indicator lamp is still on. I guess I'll bring it down to Ford and see what they can do about it.
Old Oct 11, 2009 | 05:17 PM
bewtew's Avatar
Hmm...Just re-read your message and I dont think mine doesnt work like that. I've rotated the tires myself (cause Ford wanted $30!!) and my indicator lamp/console message didnt go off in any way.
Old Oct 11, 2009 | 05:21 PM
kingfish51's Avatar
It would not go off when rotating unless the recommended pressures were different between front and rear.
Old Oct 14, 2009 | 03:17 AM
bewtew's Avatar
update
I dont know what happened, but after a 22 mile drive to work this morning, the TPMS indicator lamp does not stay ON anymore. I'm not sure if it's working normally again. The psi is currently set to just about 50 cold (~53 when i got home from work).
