24's
Old Sep 3, 2009 | 08:58 PM
caffreym0311's Avatar
24's
does anyone know of some 24's that will fit on my 2000 stock height f-150 ext. cab stepside, ive looked and cant find anything on here.... any help out there?
Old Sep 3, 2009 | 09:38 PM
Fuerte150's Avatar
Most 24's will fit, just need to find the ones with the correct backspacing.
And, the right tire.
Those are the only two things to worry about. Other than actual lug fitment.
Lots of sites can give you fitment suggestions. Even sites like www.discounttire.com.
Old Sep 5, 2009 | 02:32 PM
Damon@tirerack's Avatar
Former Sponsor
Depending on the model, 285/35 24 is the closest size in OD to stock. Problem is, they barely have the load capacity to support the weight of the truck. Put a decent load in the back? Forget about it. Stick with 22.
Old Sep 6, 2009 | 06:44 PM
so your sayin they dont make a 24 that will hold the load of my truck??!! im pretty sure they make wheels and tires to hold the weight...
Old Sep 6, 2009 | 07:36 PM
aPINCHbetter90's Avatar
He is trying to say that without any lift and the 24's your barely putting any rubber wrapping the wheel which would probably have a very low load rating. You need to lift a little bit and get a tire that is a little bit bigger also to support your truck.
Old Sep 6, 2009 | 10:17 PM
wandell's Avatar
He said that would be if you stay with a 24 inch tire that is the same height as the OEM tire. I'm not an expert on fitment on the 4x2 97-03 F-150's with street tires, but I would try to fit a 305/35-24 tire which is basically a 33x12.50-24 tire. This will give him a good bit of sidewall. I know one thing, you don't want to lift a truck to fit a street tire/wheel package, ever. I'm sure you don't want to wind up with a F-150 donk.
Old Sep 7, 2009 | 11:16 AM
well right now i got 20" chrome lightning replica wheels with 275/45's and i got alot of space to play with... i think the rear end was lowered because it sits about an inch lower than the front....
Old Sep 8, 2009 | 09:14 AM
Former Sponsor
I guess I should have made myself more clear, sorry guys.
24's will fit, and 285 mentioned above will fit the wheel and fit witout any worry of rubbing. But if the OD is the same as the stock 16" wheel you are removing 4" of sidewall from the tire and replacing it with wheel. That reduction in size is also a reduction in air volume, which determines the load capacity of the tire. 285's do work OK, but it's too close to be a good idea. We recommennd a 305/35 24 as it has much more load capacity. But depending on the offset of the wheel or unless you are lifted in fron you may need to due some liner trimming to get it in.
Old Sep 15, 2009 | 09:20 PM
Oh ok, my bad, I just got back to the states so tomorrow I'm going to look at some wheels at this wheel and tire shop, hopefully they'll be a little bit more help with fitment. Also, I'm not really sure what the suspension is like because, even though i live in a fairly large city, I haven't seen an extended cab stepside f-150 so i don't know the stock height.... Does anyone think they can tell whether or not its stock height by a picture?
Old Sep 20, 2009 | 11:52 AM
bump
