Tire Pressure Question
Old Aug 25, 2009 | 07:29 PM
DaMoose81's Avatar
I have LT295/75 17's and i had a question on tire pressure. The tires are load range D with a max psi of 65. I have been currently running them at 38-40, should i bump it up a little? A guy i work with said he runs his tires at 50 (almost the exact same tire).
Old Aug 25, 2009 | 07:40 PM
I would try 42 to 44psi and see how they ride. The more air the more miles per gallon you get on the highway. Just check for abnormal wear patterns in the center of the tires. I always run that amount in my tires and have had good luck.
Old Aug 26, 2009 | 07:23 AM
kingfish51's Avatar
38-40 is a bit low. Personally I would run them at 45.
Old Aug 27, 2009 | 07:35 AM
DaMoose81's Avatar
alright, ill try out 44-45 today. Thanks for the help
